Overview
This VI confirms that the MD5 checksums of the files are the same and then extract the files to the specified directory
Description
This example program is designed to be used in conjunction with this LabVIEW example. It assumes that there is a ZIP file as well as an MD5 checksum stored in a text file titled <ZIP File name>_MD5.txt. If both these files are present, this code will confirm that the MD5 checksums of the files are the same and then extract the files to the specified directory
Requirements
LabVIEW 2012 or compatible
Additional Information or References
VI Block Diagram
For more information on the MD5 algorithm, please see this Wikipedia article.
**This document has been updated to meet the current required format for the NI Code Exchange. **
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
