Example Code
Programmatically Counting The Number of Front Panel Windows Open in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI exemplifies how to programmatically count the number of front panel windows open at any time by using an Application Property Node to count the number of VIs currently in memory.
Description
This VI uses the property named “Front Panel State”. There are six possible results of this property node: Invalid, Standard, Closed, Hidden, Minimized and Maximized. If the state is Invalid or closed is not counted as “open”.
This could be useful to keep track of how many front panels of our application are open and verify if the memory is being handled in a correct way.
Requirements
LabVIEW Base Development System.
1. Open the attached VI named “Open Front Panel Counter LV 2012 - NI verified.vi”.
2. Run the VI.
3. Read the value of the indicator named “Number Of Front Panels Open”.
Additional Information or References
Many thanks for using the NI forums and I look forward to your reply.
Kind regards
David
National Instruments UK
