Overview
This example VI demonstrates how to export data from LabVIEW to DIAdem, run a .VBS script from LabVIEW and copy the result to clipboard.
Description
In LabVIEW, thanks to the LabVIEW DIAdem Connectivity VIs, you are able to programmatically launch DIAdem, import data from LabVIEW, run .VBS scripts programmatically and save the report in different formats. In this case, an array is exported from LabVIEW and the attached .VBS code is subsequently run to plot constant lines in the final report.
IMPORTANT NOTE: The LabVIEW DIAdem Connectivity VIs are not supported starting from LabVIEW 2010, as specified here.
Requirements
Additional Information or References
VI Block Diagram
