Example Code
Programmatically Create LV Projects with Virtual Folders
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Use VI Server to programmatically create and add virtual folders to your LabVIEW Project.
Description
In many occasions, we need to create projects with a specified structure. This VI shows how we can create a project programmatically with virtual folders, or modify a project already created.
Requirements
1. LabVIEW Base Development System (or compatible)
1. Choose whether you want to create or modify an existing LabVIEW Project.
2. Select the name of the LabVIEW Project that you would like to create or modify. Do not use the extension, since the code already adds it.
3. Search the folder that contains the LabVIEW Project or the directory where you would like to save it.
4. If desired, add the names of the virtual folders that are desired to have.
5. Run the VI.
Additional Information or References
A_Ryan
AES
