Example Code
Programmatically Create Smaller TDMS Files
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example demonstrates how to split large tdms files into smaller ones.
Description
This example shows how to take a large TDMS file and create a series of smaller TDMS files that include subsets of the same information. The iteration terminal is used to uniquely identify each TDMS File as ...parti.tdms.
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Download and open the attached file
  2. Run the program
Additional Information or References
Split TDMS File into smaller TDMS Files LV2012 NIVerified.vi - Front Panel.png
Split TDMS File into smaller TDMS Files LV2012 NIVerified.vi - Block Diagram.png
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
A_Ryan
AES
Comments
ColdenR
NI Employee (retired)
on
I created an example similar to this one that handles memory errors associated with trying to write files that are too large. For example, you could split a 2 GB TDMS file into 250 MB chunks using this other example, even if you don't have much memory available.
https://forums.ni.com/t5/Example-Code/Split-up-Large-TDMS-file-Allow-larger-than-memory-file-sizes/t...
Colden
