Overview
This example program demonstrates the process for using the VeriStand .NET API to programmatically create a conditional Calculated Channel.
Description:
Since the main VI is also designed to run alone, this example also creates a new System Defintion file, adds a User Channel, adds the Calculated Channel, then Closes and Saves the System Definition file. However, the VIs for creating the SDF, adding User Channels, and Saving and Closing are identical to those found in the VeriStand examples located at <LabVIEW>\examples\NI Veristand\API\System Definition API\Support.
Steps to implement or execute code
To implement this example:
Requirements
Software
LabVIEW 2012 or compatible
NI VeriStand
Hardware
