Example Code
Programmatically Delete Item from Project or LVLIB in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This code allows the user to delete programmatically an item from a Library or Project.
Description
This VI accesses programmatically to the Project Items using Invoke and Property nodes. The user types the Item (could be a Shared Variable, OPC or any Project Element) to delete from the LVLIB or Project in a String Control, if this Item is in the LVLIB or Project it will delete.
Requirements
LabVIEW 2012 (or compatible)
  1. Verify Variable 2 is located in the Project and type "Variable 2" in the Child of .lvlib to delete Control
  2. Run VI
  3. Specify the path of the project that includes the Library
Additional Information or References
RIO Embedded Hardware PSE
CompactRIO Developers Guide
