This VI is an example of how one could programmatically handle the case where error/warning 66030 appears in RT code due to the scan engine being in in incorrect operating mode.
The real question is why does this happen in the first place? I notice that when I get a cpu spike sometimes something trips and the scan engine starts spewing 66030 warnings.
The mode is in Fault condition so I usually just reset the target, but really need to prevent this from happening in the first place.
I have one cRIO 9074 and two cRIO 9144 using EtherCAT into Scan Mode and sometimes I receive the error 66030. Then I try to put the code that you suggest. So, now I receive the same error 66030 followed by -66450 error.
I try to stop program and start again and the happens the same. If I restart cRIO (Project Window > cRIO > Utilities > Resart) it solves the problem until next time.
Any idea about how to solve it automatically?
