Example Code
Programmatically Load/Save 'Default' Control Values Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
The example to save and load front panel control values to/from a .ini file.
Description
There are a number of ways to save a set of control values to load at a later date. Here are two VIs which allow you to save and load front panel control values to/from a .ini file. The example automatically populates an xml file with all current control values to the VI's front panel.
Requirements
  • LabVIEW 2012( or compatible)
  1. Run the vi.
  2.  Hit 'save' - this will save a .INI file with all control information to the specified path
  3.  Hit 'load' you will notice that they return to the originally saved values
Additional Information or References
Front Panel
Eden S
National Instruments UK & Ireland
Comments
steve_robbins
Member
Member
on
Many thanks,  this works very well!  Even on array of clusters containing arrays of clusters!!!!
Tom98765
Member
Member
on
Really nice, even with hideously complex controls, but not if there are controls with multi-line labels. Very many thanks.
