Example Code
Programmatically Resizing and Filling an Array in TestStand
Products and Environment
    Software
  • Teststand
Code and Documents
Description
Overview
This example demonstrates various methods of using the TestStand expression language to resize arrays and populate all elements of the array with an initial value.
Description
TestStand allows you to define array variables which are initially empty. In some cases, you may want to programmatically set the size and dimensions of the array, as well as assign an initial value to all elements of the array. The TestStand expression language includes a set of array functions that can be used to perform these operations.
The example demonstrates the following techniques for performing these tasks:
  •  Assigning values to an array using an array literal string.
  • Using the SetArrayBounds() TestStand expression function to set the size of a single or multi-dimensional array.
  • Using the SetElements() TestStand expression function to populate every element of an array with a specified value.
Hardware and Software Requirements
Initialize Arrays_NIVerified.zip
TestStand 2010 or Compatible
Initialize Arrays Legacy_NIVerified.zip
TestStand 2.0 or Compatible
LabVIEW Development System 5.1.1 or Compatible
  1. Open the attached sequence file.
  2. The sequence file is organized such that each approach for resizing and filling arrays is located in a separate sequence. Examine each sequence to understand the various approaches and TestStand expression methods being used.
  3. If desired, you can set a breakpoint at the end of each sequence to allow you to examine the value of the array variables after each sequence executes.
  4. To run the example, with the MainSequence selected in the Sequences pane, click Execute » Run MainSequence.
Mark M.
Applications Engineering
