Example Code
Programmatically Run a VI on an RT Target
Code and Documents
Overview
This project is meant to show how to run a VI on a target computer from a host.
Description
Sometimes multiple types of functionality is needed at runtime from an RT target to a host computer.  To dynamically call VIs to implement this functionality a source distribution must be used.  This example is in reference to this Knowledge Base article: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIE4CAO&l=en-US
Requirements
  • LabVIEW 2012 compatible, with LabVIEW RT
  1. Build a deploy the source distribution on the RT Target
  2. Open "Host.vi"
  3. Input the IP address of the target
  4. If no changes were made to the target VI, run the VI and watch the Output indicator count down from 0.
  5. Pressing stop will reset the VI and running it again will start the counter at 0.
Additional Information or References
 **This document has been updated to meet the current required format for the NI Code Exchange. **
Bobby Breyer
