Example Code
Programmatically Set an Image as Front Panel Background
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
Overview
This example demonstrates how to set the background image of a Front Panel programmatically through VI Server.
Description
This example uses VI Server to programmatically set the background of a Front Panel to an image loaded from disk.
It converts a VI's file path to a reference to the VI using Open VI Reference. The reference to the VI enables you to access the panel of the VI. The panel itself provides programmatically access to all panes. The pane offers a BackgroundImage property node. The example loads an image and populates the image to the BackgroundImage property node.
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Download and open the attached ZIP-file
  2. Open the [Main] ...VI and follow the instructions on the Front Panel
Additional Information or References
[Main] Set Image As Front Panel Background - Front Panel.png[Main] Set Image As Front Panel Background - Front Panel.png
[Main] Set Image As Front Panel Background - Block Diagram.png[Main] Set Image As Front Panel Background - Block Diagram.png
If you would like to apply the image to the background of the current VI's front panel, replace Open VI Reference with VI Server Reference available in the Application Control palette.
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Comments
Khazman
Member
Member
on
how to revert back the vi to normal condition?
