Example Code
Programmatically Show Table Scroll Bars
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Coding that exemplifies how to programmatically show the scroll bars on a table control.
Description
The scroll bars for table controls can only be on or off. However sometimes it is desired to have the scroll bars turned on only if there is enough data in the table to need them. This can be done programmatically by checking if the size of the array is greater then the amount of rows and columns that are visible, and then changing the "Vertical Scrollbar Visible" property accordingly.
Requirements
LabVIEW 2012 (or compatible)
1. Insert the amount of data into the table as desired.
2. Select the Run button.
Additional Information or References
