Overview
Coding that exemplifies how to switch dynamically between two front panels of different VIs.
Description
These two VIs, if located in the same folder, will switch between the two of them when you press the Boolean on the front panel. This is done programmatically. Each VI calls the other, and bring its front panel to the front.
Requirements
LabVIEW 2012 (or compatible)
1. Run one of the VIs
2. Select the Boolean control
3. When the second VI is open, select its respective Boolean control.
4. Stop both VIs by using the respective Stop button.
Additional Information or References
First Screen
Second Screen
