Description
Description-Separate-1This example code shows how to use DAQmx property nodes to programatically detect hardware devices connected to your systems that can perform a hardware-timed analog output task.
Example uses of this code include checking for hardware AO generation compatibility before fully loading or executing functions in your LabVIEW VI or LabVIEW built executible.
Potential code modifications include changing the property nodes to screen for:
- Maximum input or output rates to automatically adjust measurements (or generation) to the performance of the hardware
- Hardware device type to adjust capabilities in software to match those available with hardware (channel counts, number of counters, etc.)
Description-Separate-2
