Overview
This example can programmatically search all of the National Instruments DAQ cards attached to machine for a specific product.
Description
This example uses a DAQmx System property node to access the list of discovered device names, and then a DAQmx Deviceproperty node to determine the product type of each of the discovered devices. If need to use a specific device type (eg. PCI-6221 regardless of the name which MAX has assigned to it
Requirements
Additional Information or References
VI Block Diagram
