Overview
This code allows the user to simulate an Indicator Radar Sweeping using Picture functions.
Description
This VI uses the Picture Functions API to draw a sweep radar simulation. Picture Area Size is using as reference for get the center of the radius and X and Y Offset then the circle, the center and the swept line is drawing. A Formula Node calcules the sine and cosine for an angle that is changing each iteration. The user is able to change some Radar Indicator Properties as: Direction, Line Style, Color and Width.
Requirements
LabVIEW 2012 (or compatible)
Additional Information or References
