Overview:
This code allows the user to use a remainder in order to select a random array element.
Description:
The VI features taking in the current background color and averaging the contrasts of the red, blue and green fields to determine whether to use a dark or light font. The background flashes back and forth to random colors, adding a fun game show style to the atmosphere.
Requirements
LabVIEW 2012 (or compatible)
Additional Information or References
Additional Note:
If over a hundred array elements are added, you will need to change the multiplication factors of the random numbers to accommodate for this. The VI currently selects a random color and places this in the text box then switches back to the default color before doing so again. If the user wants to they can disable the case structure and only use random colors.
