Example Code
Read Fixed Width Data Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Some input files will be in a fixed width format. These can be relatively easily interpreted by loading them in to memory as strings and then converting them numerically, but for very large files and systems with modest resources this could be problematic. This vi solves that problem.
Description
This vi uses a series of loops to parse the line of hyphens and spaces below the column headers and calculate column width and number of columns. It then uses the scan file vi, along with the calculated column width and number, to read the numeric values directly from the file, bypassing the conversion from strings and thus saving memory.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Format the data file to have the line separating the data from the header in the manner illustrated in the attached example file.
  2. Create code to parse the header data as required.
  3. Process the data as desired.
Additional Information or References
VI Block Diagram
