Example Code
Read of Folder of Images and Return File Paths Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This simple example demonstrates how we can return the file paths for all images in a particular folder, and output the paths as an array.
Description
This VI reads in a single image's file path from a particular folder. Then by using the List Folder.vi inside of a For Loop, every image that has the specified file extensions (.tif, .jpg, .png) is returned. These image's names are then added into a folder path and returned as an array.
Requirements
LabVIEW 2012( (or compatible)
  1. Choose the image file path
  2. Run the vi.
Additional Information or References
Front Panel
VI Snippet
Cole R.
Software Engineer
