Overview
This example shows File I/O (read and write) with TXT's and also inserts the read strings into a report.
Description
- First, we declare a global variable which is available to Script and Report (in my case "valar(4)").
- In the report, we write the variables entries (e.g. @@valar(0)@@) to the desired locations.
- In the script, the TXT gets opened, read and the strings are written into our variable (some TXT output is also produced).
- Generate and refresh the report.
Hardware and Software Requirements
DIAdem Base 2012 SP2 (or compatible)
1. Unzip TXT Read Write Report - DIA2012SP2.zip.
2. Run Read TXT.VBS.
Additional Information or References
Eric H.
Applications Engineering
