Example Code
Reading the linear Position with Balluff Encoder and CANopen
Products and Environment
    Hardware
  • PXI CAN Interface Module
Code and Documents
Description
Introduction
This VI´s shows, how to read the absolute linear Encoder Position from the Balluff Encoder (BTL5-H1...) with the National Instruments CANopen Library.
This is a reduced example for one positionsensor.
The first part reads the name of the device with a SDO, the second part reads the PDO continously.
Additional Notes
What you need to get started:
At least
for further Communication Possibilities click here.
#1: Open the attached Example
#2: Set the appropriate Interface, Baudrate nad Node ID
#3: Run the Example and see the position and the velocity
