Example Code
Reconnecting Network Streams using a State Machine using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example demonstrates how to reconnect Network Streams using a simple State Machine Architecture.
Description
Here is a brief description of the example:
This example was created based on the Simple Network Streams found in the NI Example Finder.  We utilized a state machine on the Reconnect Network Streams - Target program.  This allows the program to properly close the Network Stream when it gets disconnected from the host (stopping the host VI).  Then the program moves into waiting for reestablishing a connection with the host.
Requirements
  1. LabVIEW 2014 (or compatible)
  1. Run Reconnect Network Streams- Target.vi
  2. Run Reconnect Network Stream- Host
  3. Click Stop on the Reconnect Network Stream- Host
  4. If the Reconnect Network Streams - Target.vi is running you should then be able to run this VI again and communicate over Network Streams.
Additional Information or References
VI Snippet
The Host VI:
Reconnect Network Streams - Host 2014 NIVerified.pngReconnect Network Streams - Host 2014 NIVerified.png
The Target VI:
 Reconnect Network Streams - Target 2014 NIVerified.pngReconnect Network Streams - Target 2014 NIVerified.png
M. Whitaker
ni.com/support
Comments
donkdonk
Member
Member
on
Just what I am looking for!
Unfortunately I am not able to run it because I use LabVIEW 2013 (the project was saved in LV2014).
Could you please make it available for LabVIEW 2013?
