Overview
This code allows the user to understand some fundamental concepts for the 3D Picture by animating an image of the solar system.
Description
This example demonstrates some fundamental concepts for the 3D picture. Concepts covered include object creation, texturing, object movement, and object hierarchy. There is a lot of interaction that the user can have with the control, and it may be desirable to record their interactions with the picture control. Fortunately, there is a property of the control called ModelViewMatrix, which allows one to programmatically monitor the current camera position, in relation to the 3D object being viewed. Using a property node, one can continuously monitor the position of the camera viewing the 3D picture, and record these movements if desired for playing back at a later time.
The attached VI is a modified version of a LabVIEW shipping example for observing a solar system. This one is modified to monitor the ModelViewMatrix property, and record its current values every 2ms. If the user then wants to play the recording back, they can click the playback button to view the recording camera movement.
Requirements
LabVIEW 2012 (or compatible)
Additional Information or References
