Example Code
Remove Duplicate Strings from a String Array using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows a method of removing duplicate string values from an array.
Description
The Remove Duplicate Strings from Array VI will take an array of strings and use them as names for attributes of a Variant. Because Variants in LabVIEW cannot have multiple attributes of the same name, duplicates are removed. We then retrieve the names of all Variant attributes, sort them, count them, and return them to the user as the array of strings with duplicate values removed.
Requirements
  • LabVIEW Base Development System 2012 (or compatible)
  1. Download the attached VI to your computer
  2. Open the VI " Remove Duplicate Strings from Array 2012 NIverified.vi"
  3. Run the program
Additional Information or References
VI Block Diagram
Milan
Comments
Mads
Trusted Enthusiast
Trusted Enthusiast
on
A novel approach...I first thought it was much faster than my own implementation, but I had mixed the two up.
The variant-based method is 3-4 times slower than this one.
