Overview:
This code allows the user to remove items from a run-time menu of a control/indicator in the Front Panel.
Description:
Using Event Structure and based on the Shortcut Item to Remove Enum Control, the associated shortcut menu item on the Waveform Graph will be removed.
This uses the Delete Menu Items VI to remove the menu item.
Requirements
LabVIEW 2012 (or compatible)
Additional Information or References
This topic is very helpfull, thanks
