Example Code
Remove Max and Min then Take average of the remaining Data.
Products and Environment
    Software
  • LabVIEW
    Programming Language
  • LabVIEW G
Code and Documents
Description
This example will Remove Max and Min then Take average of the remaining Data whatever measurement data you are pulling.
I might think this will be useful to those who will find this code:
Made with LabVIEW 9.0
How to Use
vi Attached, Enjoy!!!!
Related Links
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
Comments
crossrulz
Knight of NI Knight of NI
Knight of NI
on
@syrpimp wrote:
1. No need for the Array Size to go into the FOR loop.  The autoindexing tunnel will tell it how many times to iterate.
2. No need for the Search 1D Array.  The Array Max & Min have outputs for the indexes of the max and min.  So just build those into an array, sort, and then use the loop with just Delete From Array.
3. If all you actually care about is the average, then just add all of your values, subtract the max and min, and then divide by (array size - 2).  No loops required then.
syrpimp
Member
Member
on
TAHNKS
syrpimp
syrpimp
Member
Member
on
syrpimp
crossrulz
Knight of NI
on
@syrpimp wrote:
With the second option, you need to sort and reverse the index array, otherwise you will delete the wrong value if the max came before the min.
I'd like to see some benchmarks, but I would guess that option 3 would be the most efficient since it does not involve messing with the potentially large array.
syrpimp
Member
Member
on
syrpimp
Contributors
