Example Code
Remove Trailing Space from String
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI can be used as a subVI to remove a trailing space from a string.
Description
A trailing space is a space following the last character of a string. For example, "test " contains a trailing space, but "test" does not. Running this VI would convert "test " to "test" by removing the trailing space.This sub VI in a For Loop to remove trailing spaces from each string in the array.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Input a string
  1. Run VI
Additional Information or References
VI Block Diagram
Daniel Hays | Software Product Management
Comments
crossrulz
Knight of NI Knight of NI
Knight of NI
on
What's wrong with just using the built in Trim White Spaces?  There is an option to have it only trim the end.  This way you can remove multiple spaces that are trailing (which I have ran into plenty of times).
Daniel_H1
Member
Member
on
Hi crossrulz,
The built-in Trim Whitespace VI will remove all spaces, tabs, carriage returns, and linefeeds. There are times when you may want to cycle through many strings and remove the spaces, but leave tabs or carriage returns at the ends of other strings. Basically, this gives you a little more specificity.
