Overview
I have a data array full of elements but I would like to put them in a certain order. How can I accomplish this?
Description
The following VI is built so the user can indicate the desired corresponding index for each element in the mapping array. For example, if you would like data array element 0 to be in element 3, then the first element of your mapping array would be 3.
This method requires the programmer to know exactly how they would like to reorder their data array.
- Input desired order into mapping array
- Make sure you have a 1-D data
Requirements
Attached VI is written in LabVIEW 2014.
Additional Images or Video
