Example Code
Resample Waveform to Preserve Shape using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI resamples a waveform in order to retain its shape. This may reduce or increase the number of samples depending on the highest dominant frequency. This VI is designed to be used as a subVI.
Description
This example VI resamples a waveform in order to retain its shape. This may reduce or increase the number of samples depending on the highest dominant frequency. There is a peak detector in the frequency domain used to find the highest frequency above the power average. The resample factor will be the number of samples divided by ten times the highest frequency.
If the signal repeats this may detect the repeatability and will output a short waveform resampled for the repetition. This may be useful for significantly reducing the amount of data sent. The short sample is most useful for continuous waveforms.
This has not been tested for noisy signals and may not work for signals larger then 1M samples. If the highest frequency detected is more than ten times the number of samples this will not be effective at reducing the number of samples.
Requirements
  • LabVIEW 2012 (or compatible)
1. Set the waveform in
2. Run VI
Additional Information or References
VI Block Diagram
 Resample for Shape LV2012 NI Verified.pngResample for Shape LV2012 NI Verified.png
Vince M
