Example Code
Resetting the Iteration Count for a Specific Case
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview: Counting the iterations required on the user condition.
Description:
This VI demonstrates a question that was brought up in the NI discussion forums. When ran, the VI will wait for a conditional. Once the conditional is met (in this case, a boolean control) a different case will be used in the case structure. Inside of the case structure, the iteration count will start at 0 and continue for a user set amount of iterations. Once the iteration count is met, the boolean resets to false and the iteration count is reset to 0.
Requirements: LabVIEW 2012 (or compatible). Hardware: none.
Steps to Implement or Execute Code:
1. Run the VI.
2. Switch on conditional control.
3. Look on the String indicator.
4. Change Iterations to run.
Additional Information or References:
This example is in reference to this discussion forum
Chris Van Horn
