Overview
This program creates an array of 100 random elements, plots the data to a waveform graph, and retains the previously plotted data as it creates and plots a new array of 100 elements.
Description
The outside While Loop allows this program to run until the user presses the STOP button, and is used to retain the previously plotted data
using a shift register. The inside For Loop indexes through the elements of the blank array, creating the new data to plot.
This can be utilized to see differences in data graphically or to compare instances of the same measurement or process.
Requirements
Additional Information or References
VI Snippet of Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
