Example Code
Retirement Calculator Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Implement a Retirement Calculator to determine if you are saving enough to meet your retirement goal.
Description
Calculator considers various factors, including current retirement savings, current compensation, future earning potential, inflation, savings contribution rates, current age, expected retirement age, life expectancy, return rates on savings, and retirement costs, to calculate retirement savings balance, investment returns, savings contributions, and savings withdraws per year. Descriptions for the various factors can be in the tip strip. Calculator does not consider benefits from a pension or social security.  Data from calculator can be viewed in the program itself and/or exported to a text file.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Run the VI
  2. Change variables to match your circumstances and expectations
  3. Calculator will execute each time a variable is changed
  4. Select if you would like the data plotted in the program itself and/or exported to a text file. Detailed results from calculator are located on the second tab.
  5. Press the stop button to stop the calculator
Additional Information or References
VI Block Diagram
