Example Code
Return Current System Language Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Get the System Language of the OS via a kernel32.dll call, returning the value as HEX.
Description
Get System Language.vi calls GetSystemDefaultLangID() to return a both a numeric and hex representation of the default system language.  This value may be compared with the table on this page.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download and unzip Language Hex Codes.zip.
  2. Run Get System Language.vi.
Additional Information or References
VI Snippet
Comments
Thoric
Trusted Enthusiast Trusted Enthusiast
Trusted Enthusiast
on
Note this uses the "GetSystemDefaultLangID", which returns the default language of the system, which is the language of the operating system at install time. This won't return the current language. For example, my system is set to UK, yet this returns US as the language. If instead you call the "GetUserDefaultLangID" function you get the actual current language of the logged in user.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
