Example Code
Rotate 2D Array Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI rotates a 2D array either clockwise or counterclockwise by 90, 180, or 270 degrees.
Description
This is done by iterating the array through a for loop and using the Transpose 2D Array VI.
Requirements
Software:
  • LabVIEW 2012 (or compatible)
1. Select Rotation orientation.
2. Run the VI.
3. Inspect Rotated 2D Array indicator.
Additional Information or Resources
Dan King
