Example Code
Run Power Point Slideshow (ActiveX) Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example will prompt the user for a PowerPoint slide show presentation .pps file and then launch PowerPoint and run the slide show in a full screen.
Description
This example  is based on Active X to call PowerPoint slides and  launch PowerPoint automatically
Requirements
  • LabVIEW 2012( (or compatible)
  1. Run the VI.
  2. Specify a PowerPoint file(.pps or .pptx) in the pop-up dialog.
Additional Information or References
VI Snippet of Block Diagram
Regards
Prabhakant Patil
