Example Code
Running Lights Front Panel Animation in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
1. Overview
This examples shows how to implement graphical running lights, where an area defined through a picture object is repeatedly filled by a sequence of lights or any graphical object read from a file.
2. Description
For industrial applications, like conveyor belts or material or energy flow, you may want to implement running or moving graphic objects on the front panel. This examples shows how to implement graphical running lights, where an area defined through a picture object is repeatedly filled by a sequence of lights or any graphical object read from a file. These graphic is shifted in a loop so that the objects are running through. Pre-allocating the graphics makes this much more CPU efficient as using Property nodes to move graphics around on the front panel. During movement, each light or graphical object can be switched on and off. Direction of movement is automatically determined by largest dimension of picture, or can be set manually. Supports JPG PNG and BMP pictures.
3. Requirements
  • NI LabVIEW Base Development System 2012 (or compatible).
4. Steps to Implement or Execute Code
  1. Download, unzip and open the compressed project "Running Lights Front Panel Animation LabVIEW 2012 NIVerified.lvproj".
  2. Open "RL_Example.vi".
  3. Run the VI.
  4. Switch the Light states to turn the color arrows on and off.
  5. Click Stop when finished testing.
5. Additional Information or References
Running Lights Front Panel Animation Screenshot.PNGRunning Lights Front Panel Animation Screenshot.PNG
Running Lights Front Panel Animation FP Screenshot.PNGRunning Lights Front Panel Animation FP Screenshot.PNG
**The code for this example has been edited to meet the new Community Example Style Guidelines.**
Comments
mxyyyeoleyyw
Member
Member
on
This is such a cool example! I’ve been trying to figure out how to make smooth conveyor/flow animations in LabVIEW without using tons of CPU, and this is perfect.
The pre-allocated graphics trick makes so much sense — I’ve always used property nodes which kill performance. Can’t wait to pull this apart and adapt it for my industrial UI. Thanks for sharing!
