Overview
Save all VIs with an open Front Panel to a file.
Description
I was working with a customer who often has many VIs open at the end of the day. At night IT would push updates which required his computer to be restarted. I created the VI to save all VIs with an open Front Panel to a file. Also, I created the VI to load all the files previously saved in order to open all the different VIs the customer was working on.
Requirements
LabVIEW 2012 (or compatible)
1. Open the attached "Save list of VIs with open front panels LV2012 - NI Verified.vi"
2. Run the VI
3. When prompted, select a location and file name to save the list of Open VIs
4. When ready to re-open this list of VIs, run the attached "Load VIs from saved list LV2012 - NI Verified.vi"
5. When prompted, select the location of the previously saved file
6. All listed VIs will re-open
Additional Information or References
Save VIs
Load VIs
