Overview: This example demonstrates how to save and load the current configuration of a front panel using a binary file.
Description: This example demonstrates how to save and load the current configuration of a front panel using a binary file. This allows the user to quickly save a configuration without needing to manually setthe defaul values for the controls. Also, the save file can be distributed with the application, and used to back up configurations.
Requirements: LabVIEW 2012 (or compatible). Hardware: none.
Steps to Implement or Execute Code:
1. Run the VI.
2. Use controls to manage controls' state.
Additional Information or References:
Please add a few tags to this document and rename the attachment to include the LabVIEW version. "_lvXX.vi" is good enough.
