Example Code
Scale Multiple Images using LabVIEW
Products and Environment
    Software
  • Vision Development Module
  • LabVIEW
Code and Documents
Overview
This example demonstrates how to resample and scale multiple images.
Description
While using the TimeLapse VI (which can be found on the community) I found that the videos being created were extremely large due to the size of my photos, the resolution options on the TimeLapse.vi did not maintain the aspect ratio of my images. I decided to create a VI that could convert multiple images to a new resolution while maintaining their aspect ratios. This is attached as a project.
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
  • NI Vision Development Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Download and open the attached file
  2. Run the program
Additional Information or References
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Joel G
National Instruments UK & Ireland
