Overview
Being able to generate data from multiple HSDIO devices using NI-TClk allows a programmer to effectively expand their channels.
Description
Being able to generate data from multiple HSDIO devices using NI-TClk allows a programmer to effectively expand their channels. With NI-TClk you can generate synchronized data across several devices with very little jitter. Being able to add scripting into the program, allowing greater control over the behavior of your HSDIO device, would be extremely useful.
Requirements
Software
LabVIEW 2012 (or compatible)
NI-HSDIO driver which is compatible with your hardware and version of LabVIEW
Hardware
NI-HSDIO Devices
Instructions
1. Select the devices in Resource Names.
2. Run the VI
Additional Information or References
.png)
Dan King
