Example Code
Search and open file in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
1. Overview
Example VI that allows the user to make a file search in a certain folder, get a list of the files present in the folder and finally select to open one.
2. Description
This example code shows how to use event structures, subVI calls, and the browser library to show and open different files using LabVIEW. The project contains a main VI called “Search File”, which allows the user to select a folder to search for files, as well as a search criteria, in case there’s any.
It also includes an additional subVI called “Select File” which displays a given array of found files and waits for the user to click in one of them.
If there are no files to display, the program will display a message to the user.
3. Requirements
  • NI LabVIEW Base Development System 2012 (or compatible).
4. Steps to Implement or Execute Code
  1. Download the compressed file and open the project “Search and open file LabVIEW 2012 NIVerified.lvproj”
  2. Open the VI “Search File.vi”
  3. Run the VI.
  4. Select a Folder Address for the search.
  5. Write a Search Criteria, (use * as a wildcard)
  6. Press the Search button and select a file from the list.
  7. Press Stop when done.
5. Additional Information or References
**The code for this example has been edited to meet the new Community Example Style Guidelines.**
Francisco Arellano
National Instruments Mexico
Field Systems Engineer - Energy Segment
www.ni.com/soporte
