Overview
This VI will search through a known set of data, and determine when the data exceeds a certain value.
Description
When the data exceeds that value, another array is created, and the corresponding indexes of "data to be copied" will populate that array. When the data does not meet that threshold, the new array instead contains 0s.
Requirements
Additional Information or References
VI Block Diagram
You have rube in this code:
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Bernard Books
I appreciate the comment, but I have to say I have no idea what a rube is. Would love an explanation if you have time ![]()
A rube is short for Rube Goldberg code. Rube Goldberg is famous for creating machines that are overly complicated to do simple things. It's used by this community to attribute complex code to do something that can be significantly simplier. There's a great thread to read examples of these and how they can be simplier here: http://forums.ni.com/t5/BreakPoint/Rube-Goldberg-Code/td-p/399999
Great, thanks for the information! Appreciate it.
