Overview
This example allow user to select the folder.
Description
In default labview dialog box we need to go inside the folder and press current folder button to select the folder.This example will overcome this issue.
Requirements
Additional Information or References
VI Snippet
Please click on like if you like it. ![]()
Your valuable suggestions are always welcome for the improvement.
Prabhakant
I have some problem with this VI. I solve only with the installation of .net 2.0 framework. Is it normal? Is not enough .net framework 4.0?
Thanks a lot
Regards
Roccato
Thanks a lot
Regards
Roccato
