Overview
This example lets the user select which channels they want to see on the plot.
Description
Each of these channels has a different Y scale that becomes visible when that channel is selected. Each channel also has a different color that matches the Y scale color for easy reference.
This example can be modified to include many more plots by adding channels to the DAQmx Task and adding a boolean control and color selector for each additional channel. We can also substitute the DAQmx part with other signal source.
Requirement
LabVIEW 8.6 or compatible
NI-DAQmx 9.0 or compatible
Steps to Implement
Additional Information or References
VI Snippet
