Overview
The example shows how to reserve only one task at a time using the serial Digital I/O C Series Modul between two tasks
Description:
The VI would be executed by using the access of the digital output of the DAQmx and, depends on the event defined by the VI, would then proceed to the next task. The trigger of the event structure would be the mouse event and would perform a read operation with the Digital Input after the generated signal is produced
Steps to implement or execute code
To implement this example:
To execute this example:
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 16.0 or compatible
Hardware
cDAQ with C series Digital IO Module
