Overview
This example demonstrates reading data from one serial port and forwarding this data to be written out of another port. This is useful when there are multiple serial ports and you are interested in sniffing or monitoring the serial communication between two points.
Description
Read the data in from one port with VISA Read and write it to another port with VISA Write. Both ports need to be configured. This example also displays a log of the data read in so that it can be viewed on the front panel.
Requirements
Software
LabVIEW 8.6 (or compatible)
NI-VISA
Additional Information or References
VI Snippet
Could anyone upload the Block diagram of this project? Or a Labview v7.1 compatible vi file?
Thanks.
Thank you very much!
A good idea。
could someone point me to the Full block diagram of this so that i can attempt to rebuild it for myself in LabView 6.0 ?
Sorry, for bumping the old thread but my requirement is similar to this.
Is it possible that from 1 port i receive the data and forward this data to 2 port as well as receive the data from 2 ports and forward to the same single port?
Hi, Just Added Serial Port Sniffer 2-way communication (Host Command <-> Slave Response) - Example Code
For Sniffing two way communication.
