Example Code
Set Filename with Current Date/Time using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example VI enables files to include the date and time in its filename.
Description
When logging lots of sets of data in LabVIEW, we often want to distinguish what each set of data represents. One way to do this, is to set the filename to match the current date/time so this simple VI does just that. All the user has to do is locate the folder that they want to save their new file to, then it will create a text file with the name Date Month Year Hour-Min-Sec.txt using some simple string manipulation.
Requirements
  • LabVIEW Base Development System 2012 (or compatible)
  1. Open the VI "Date File Name 2012 NIVerified.vi"
  2. Set the file path for the files to be saved
  3. Run the program
Additional Information or References
VI Block Diagram
 SnapCrab_Date File Name 2012 NIVerifiedvi Block Diagram_2017-7-25_21-39-0_No-00.pngSnapCrab_Date File Name 2012 NIVerifiedvi Block Diagram_2017-7-25_21-39-0_No-00.png
Tori
Student
Comments
erinyen
Member
Member
on
Hi Tori,
i am starting to use myRIO for my application and encounter some issues while saving file to USB via myRIO.
my purpose is to grab image every 5 sec and give a file name as current time/date.
myrio execute single time w/o while loop and save files successfully, somehow it runs under whileloop for every 5 sec, it cannot save image.....
not sure how it goes right...
kindly be advised and thank you very much!
btw, i have no idea of attaching VI into this dialog....
