This example shows how to use the NI System Configuration Python API (nisyscfg) package to read or set the programming mode of modules in a cRIO device with the NI Linux Real-Time OS. This can be useful if LabVIEW is not the main programming language being used in an automated test scenario.
opkg install python-pip
python -m pip install nisyscfg
If the previous line errors out, you can try using "sudo easy_install pip==9.0.3" instead.
You could also leverage a similar script and execute it remotely using SystemLink salt states. If included in a SystemLink custom salt state, the state can be defined as:
mycommand: cmd.run: - name: python <script_location> - runas: admin
