Overview
This example will show the most recent 5 elements of data acquired in an array.
Description
The example came from a specific application and hence was built to run 100 times with a 5 element array of strings. It shows the most recent 5 numbers generated in a loop in an array by writing each value to a new index in the array and cycling through index 0 through 4.
Requirements
LabVIEW 2012 (or compatible)
1. Run the VI
2. Observe the values being moved out of the array
3. Use the Stop button to finish the execution before the specified amount of times to run
Additional Information or References
